Until App version 10.7 this problem still exist.
set to 40 or 60 just small sound.
Hi Ivan,
Welcome to our community!
Do I understand correctly that the sound of your Reach RS3 doesn’t change after modifying it in the app? Which firmware version is your receiver on?
I tried to reproduce it, but it worked fine with Reach RS3. Are you using an Android or an iOS mobile phone?
Hi kornel.nemeti
Mobile Phone: Samsung Galaxy A33 5G - Android 14
Emlid Flow : 10.7
Receiver : 31.8
and yesterday it happened again, I set to 60 before working on the site.
bump… the volume goes to 100 after 1 hour.
Hi Ivan,
Can you please check if you experience the same after setting the sound on the Reach Panel?
If so, we’ll need a full system report of your Reach RS3 to investigate your case. You can also send it to support@emlid.com to keep it private.
Hi there,
Full System Report is sent to support email.
thank for you’re help.
Ivan,
I received it, thank you. Let me check it, and I’ll get back with the updates.
