Hi all,
Here is a file explain what I have down and the problem I have meet.Can
you give me some advice? Thank you very much!
I want to use two Ublox 6T to test the RTKLIB, I setup the base station and the rover station,But after nearly 20 minutes I didn’t get float or fix ,there is just single on the screen. Can you give me some advice?
My experiment is as follows:
1.Equipment
Two Ublox Lea-6t-0-001 receivers;
3DR Radio 915Mhz;
PC;
2.Software
RTKLIB V2.4.2;
3.Setup the base station
Open the STRSVR.exe;
2)Setup the Input Options;
3)Use these Commands to get the raw data and close the NEMA data;
4)Setup the output options
5)Setup the Conversion option,Ublox to RTCM3
6)Setup the STRSVR options
7)Run the STRSVR;
4.Setup the rover station
1)Open the RTKNAVI.exe
2)Setup the Input Stream
3)Use Commands to get the raw data and close the NEMA data;
4)Setup the options
5)Setup the positions options (Maybe some thing is wrong here,but I don’t know)
6)Run the RTKNAVI,after 20 minute there is just SINGLE,the BASE SNR is NONE
7)From the RKTNAV Monitor the Base station massage is below
Thanks for your reply.
my problem is i want to install the rtklib at kinematic mode and after i apply the following steps
1-install rover as the following RUL :enter link description here
the only difference between the steps explained at URL and which i apply is , I choose the base station at input as TCPClinet and write the port number (same as which i write at base station installation) .
