Thank you for this new version.
I detected a small bug in the last version of sutdio.
Some events are listed 2 times consecutively in the _event file with exactly the same time values (and other parameters are also the same). 2 times for around 400 events.
I compared with RTKLIB processing and the problem does not exist.
So I analyse the RINEX file and found that there is a flag in the line before the doublon events:
" Time mark is not valid COMMENT
" > 2021 7 9 12 19 31.7096683 5 0
Can you share the firmware version of your Reach and the logs (the RINEX ones and _events.pos from Emlid Studio and RTKLib)? It will help me see why it happens.
As I wrote to you in my first post, I analyse the RINEX file and found that there is a flag in the line before the doublon events:
Direct PPK computation with RTKLIB is correct, the bug is only with Studio.
