Hi, I’m trying to download the image from the downloads section but the link you have in the docs page in pointing to nowhere.
Link: http://docs.emlid.com/Navio-APM/Downloads/Real-time-Linux-RPi2
It is safe to assume that the image provided in this forum thread is updated?
Thank you in advance
Hi, working links to the RT image downloads are provided here:
http://docs.emlid.com/Downloads/Real-time-Linux-RPi2/
Could you please tell me where did you find the first non-working link?
Thank you for your answer.
Follows the link site.
Fixed, thanks for telling about this.
Hi the link in the first comment did not work for me when I just tried it. went to 404 Not found error.
Pedro_Alves1Pedro Alves Aug '15 1
Hi, I’m trying to download the image from the downloads section but the link you have >in the docs page in pointing to nowhere.
That is only part of the problem I have been having. I have tried different browsers, OSes, but could not get the “download” link of http://files.emlid.com/data/public/rt-20150401 to work. I have been trying to get a RaspPi2 image since Dec 26th. I have been able to build the source kernel from github, with missing details, I guessed alot, and may or may not have a good build from scratch image loaded over the top of a Raspian system image. I would rather have the same image everybody else is using.
Are there mirrors sites to download from? or is the main download site having troubles and needing reset? Any one else having download of image problems? or is there a loose nut behind my keyboard? (Don’t answer that last one.)
Update Jan6: I tried at the local library. It started downloading at a super slow buzy library speed. So, it appears my internet connection or ISP is blocking something. What does the http://files.emlid.com/data/public/rt-20150401 need (ports? protocol?) to download through a firewall at my house? I can download most anything else, why is this different?
Update Jan7: I asked a friend to download it. He must have a blazing fast connection. It was downloaded and placed on Google drive in way less than an hour. So my fix for this problem of my internet connection was to get some one else to download it for me. And then download it from Google drive. As far as the weird internet connection of mine, it has been by passed with the above solution.
Thanks for looking @igor.vereninov reninov.
My MD5 checksum ended up being - a183c76fa93fa37b789d006d8cdd1a92
[SOLVED]
@agibson
This is the first report of this kind, so I am sure there is some weird issue with configuration on your side. I have just tested everything once again and it works.
You can try temporarily disabling firewall to see if it helps.
