Hi All,
I’m not having any luck with NAVIO2 receiving or showing any RC inputs. I’ve tried a FrSky Delta 8 outputting CPPM to NAVIO2, FrSky X6R outputting SBUS into NAVIO2, as well as the using an SBUS to CPPM converter to NAVIO2.
When I go to the initial setup and radio calibration page in Mission Planner however, there appears to be no RC inputs. I’ve checked that the transmitter (Taranis X9E) is connected to the reciever. The receiver is connected to the correct pins in the correct way on the NAVIO2. I’ve also checked that the receiver outputs data, but I’m not seeing any evidence of that on Mission Planner
All of the C++ examples work except for the RCInput and servo examples, and I can receive telemetry via both UDP and ttyAMA0 which suggests to me that everything else is working ok.
I’m using a RPi2, NAVIO2 with the 20160212 image and a fresh SD card with APM installed from the deb package linked in the NAVIO2 documentation .
Incidentally, when I run i2cdetect the only address that comes up is 77, yet I still get telemetry.
Anyone spot my error?
Thanks.
