I’m having some trouble getting the Reach module to work with Navio+ on Arduplane.
Setup is as follows:
-Pi2 running the new emlid universal image
-Currently I’m running the lastest build from Ardupilot automated testing, which I believe should include ERB support.
-Reach is connected to UART on Navio
-Reach is configured according to the APM integration docs and is running ReachView 0.3.1.
-Arduplane is configured according to the APM integration docs.
-I’m running the command sudo ./Arduplane.elf -A udp:10.0.1.10:14550 -B /dev/ttyAMA0 (I’ve also tried -E /dev/ttyAMA0)
-ReachView shows that I have a GPS fix.
Ground Station shows that I have no GPS fix, and 0 sat count. I’ve also tried switching to NMEA output on the reach and still no go. What am I missing?
