[SOLVED] Emlid Studio – Incorrect GPS Coordinates and January 6, 1980 Timestamp When Processing Files from a Network Drive
I found the cause of an issue where Emlid Studio was displaying additional incorrect GPS positions, including, in my case, a point near the North Pole.
The issue was associated with the images and processing files being stored on a network-connected drive rather than on a local disk.
One of the most noticeable symptoms was an incorrect timestamp of January 6, 1980, along with an unrealistic flight path and additional GPS coordinates that did not correspond to the actual drone flight.
How I solved it:
I moved the images and the required processing files from the network drive to a local disk and ran the processing again. After doing this, the incorrect coordinates and the January 6, 1980 timestamp no longer appeared.
I’m sharing this experience in case someone else encounters the same problem, especially when using Emlid Studio with files stored on network drives or shared storage.
In my case, processing the files locally resolved the issue. I cannot confirm whether this is a general software bug or a problem specific to my network storage configuration, but it may be worth checking if you experience similar behavior.
Hi @yodalberth,
Welcome to our Forum, and thanks for sharing both what you ran into and how you fixed it. This will for sure help users who could hit the same behavior.
Processing the files locally is a good workaround, as we frequently suggest keeping project files local and on shorter paths for post-processing.
Even so, feel free to send the files and logs over to [email protected] so we can take a closer look at what happened.
