Dmytro
March 14, 2016, 6:08pm
#1
I have this:
BATT_AMP_OFFSET 0.000000
BATT_AMP_PERVOLT 17.000000
BATT_CAPACITY 4981.000000
BATT_CURR_PIN 3.000000
BATT_MONITOR 3.000000
BATT_VOLT_MULT 12.020000
BATT_VOLT_PIN 2.000000
My battery - 3Cells, 11.1V, 5100 mAh (10C - I don’t know what is this, just for a case).
How I can make Navio2 recognize battery and get data for Volt and Current ?
Hi Dmytro,
Can you try running these commands and post the output? With battery connected.
cat /sys/kernel/rcio/adc/ch1
cat /sys/kernel/rcio/adc/ch3
cat /sys/kernel/rcio/adc/ch4
After that we will be able to tell whether it is hardware or APM issue.
Dmytro
March 15, 2016, 8:22am
#3
pi@navio:~ $ cat /sys/kernel/rcio/adc/ch1
26
pi@navio:~ $ cat /sys/kernel/rcio/adc/ch3
0
pi@navio:~ $ cat /sys/kernel/rcio/adc/ch4
32
I have confused the channels, sorry about that.
You actually need:
cat /sys/kernel/rcio/adc/ch0
cat /sys/kernel/rcio/adc/ch2
Ch0 is board voltage and is supposed to be around 5V, ch2 and ch3 are voltage and current ADC measurements from power module.
Dmytro
March 15, 2016, 8:27am
#5
pi@navio:~ $ cat /sys/kernel/rcio/adc/ch0
5282
pi@navio:~ $ cat /sys/kernel/rcio/adc/ch2
1028
0
This looks correct, so hardware is fine. Ch2 (pin2) shows 1.028V which translates to about 12V on the battery. There must be some configuration in APM missed, let me check the parameters on our copter and I will post them here.
Can you try setting:
BATT_MONITOR 4
And rebooting after that.
Dmytro
March 15, 2016, 9:07am
#8
Flight battery: 100% !!! Thanks!
