I have just completed my first quadcopter build and am now struggling to create a connection between Navio+ and Mission planner so that I may calibrate all the necessary sensors.
So far I have tried running the following command on the rpi: sudo ArduCopter-quad -A tcp:11.0.0.2:5678. This brought about the following output: bind failed on 11.0.0.2 port 5678 - cannot assign requested address. Next, i tried to run sudo ArduCopter-quad -C tcp:192.268.2.15:1243:wait. This time, the output on the command line is preceded with Init APM:Copter v3.3 (340970fc) and continues with what seems to be a calibration of the barometer and gyro before i used ctr+c to stop. Both of these outputs begin with: Raspberry Pi 2 with BCM2709!
My question is, using Ethernet cable for connection (the rpi is connected to my modem), how to connect Navio+ with Mission Planner? Am I correct in thinking that the address provided after ‘tcp:’ should be the IP address of my laptop?Then what should be the address after the last colon? What message should I expect to be displayed on the rpi so that I know that I may then proceed to establish the connection from my laptop?
My apology, I am a complete beginner. Thank you for any advice!
