Hello family. After weeks of trying to post process raw logs from the rs2 to no avail, I’ve been able to finally do so using my same old Topcon tools. I decided to log some data with both reach base and Rover units in static mode. Log 3 points with the reach rover and 2 points from 2 CHC( from huacenav) L1 receivers (Meaning 3 rovers on site). Rinexed both and renamed each log (REF1 for reach base log, AAA1, AAA2, AAA3 for the 3 logs from the reach Rover and AAA4 & AAA5 for the 2 logs from the chc l1 receivers). After post processing, vectors from any of the chc receivers and (to) the reach rover logs were showing as fixed, L1 whilst the vectors from the reach base(REF1) and (to) all rover logs (AAA1 to AAA5) were showing solution type as “code diff”. I know I’m supposed to be getting fixed, l1l2 as solution type from the reach rs2 to rs2 logs. What must I be doing wrong here?? Also, what’s the meaning of code differential?? Many responses will help me here. Thanks family!
This is the processing report I generated. Thanks in advance
https://s.docworkspace.com/d/AKAsMM2P2N8eoNXGjJGdFA
I have the same problem, I tested several ways to process and it looks like L1 / code. I believe the mistake is in converting the native file into the equipment.
Hi Richard,
Could you share the software you used for post-processing? Did you try to process your logs in the RTKLIB?
May I ask you to send in the raw data logs that you tried to process so that we could take a closer look?
Hi @polina.buriak, sorry for the late reply. The above issues have been fixed since updating my RS2 devices to the latest reachview firmware (v2.21.1). I think the issue was with missing epochs from the observation data as I suggested in support to this thread " RS2 Ubx to Rinex 3.03 converting issue with EZSurv and RTKConv - #25 by richie1aubyn "
Thanks. I can finally get fixed static points over 30km away
Hi Richard,
Thanks for the report!
Good to know the issue is fixed with the firmware update
