I cannot seem to be able to find anything on this issue. I was able to set the unit up, but I left the project alone for a while. Now, when the Reach RTK unit is first plugged in, the indicator light turns magenta, blinking blue every 1-2 minutes. After 5 minutes the light turns a solid blue. No hotspot pops up, and I can’t access the unit from its IP over wifi. I tried to reflash, but the flash tool wouldn’t even recognise the unit. I tried reflashing on 2 different computers.
Sounds like Reach needs to complete a time sync. Please connect the antenna and provide Reach with some sky visibility
