This is the Project Page of SoftOSD the software HUD of NAVIO+.
In this project topic you will read about the releases of SoftOSD along with all the project news and upcoming releases.
Download Link for the base image you can find in the link below:
http://softosd.myownroot.de/EMLID_SoftOSD_v1.7z -Hosted by a server owned by @0xCCD
Link to be added by the EMLID Server.
Latest Version 0.60
Download softOSD060.7z
Download unzip and replace executable in the softOSD folder.
Change Log.
a. Code Cleanup
b. Power Module major fix. Now the power module displays the Batt Volt and Current Draw in Amperes (A).
c. Compass fix (still not functional).
d. Cleaned up debug display in SoftOSD
e. Fine Tune of code and clean up.
It is highly recomended to use the latest version.
ToDO List
- Add XML Support and implement an xml file like property file. This file will be used to add your own parameters like
FCC Callsign
Battery Capacity and voltage like 3S 4000mAh
other. - Fix Compass (NAVIO+ Hard Iron Calibration)
- Implement Baterry voltage vs Battery Capacity Algorithm to calculate the Batt Capacity.
- GPS Implementation
- VSI and AoA calculation.
- MAP Implementation
- Mouse “like” implementation of a free channel of your Radio Trasmitter.
In the near future I will comclude in various gstream implementation with the softOSD to satisfy the the will of the community.
Post your comments regarding the current version and fixes or problems you might find.
Requests for features are also welcome.
