After upgrading to the new IOS 11.3 beta, I could not longer get RS to connect as a tethered device. Mind you, it’s never easy, always having to fiddle with switching the hotspot on an off…but after the upgrade, no joy at all. I’m going to post the following:
the reach’s simple report, the sniffer output of a working DHCP discovery packet (it’s from an iphone with the ipad acting as hotspot), and last the reach’s DHCP discovery packet. The reach appears to associate with the hotspot no problem, but its DHCP discovery packets are never answered…I think. I can’t sniff a unicast reply to the reach, so the ipad might be sending a response which the reach is ignoring. In any case, every few seconds the reach re-sends its DHCP discover packet, and it never gets an IP address.
I’m going to make a wild guess. Perhaps the reach not sending option 51 (requested lease time) causes the iphone hotspot dhcp server to fail. Just a guess.
Simple system report
app version: 2.10.3-dev-r0
'wifi_status, interface: wlan0':
- Client state
- IP address: 192.168.1.103
mac address: fc:db:b3:7b:be:4a
ssid: ssw-2.4
base mode:
base coordinates:
accumulation: '2'
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- '0'
- '0'
- '0'
format: llh
mode: single-and-hold
output:
enabled: false
format: rtcm3
path: tcpsvr://:9000#rtcm3
type: tcpsvr
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '0.1'
'1008':
enabled: false
frequency: '1'
'1010':
enabled: true
frequency: '1'
'1019':
enabled: false
frequency: '1'
'1020':
enabled: false
frequency: '1'
'1097':
enabled: false
frequency: '1'
'1107':
enabled: false
frequency: '1'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
bluetooth:
discoverable: false
enabled: false
pin: '***'
correction input:
input2:
enabled: true
format: rtcm3
path: '***:***@108.59.49.226:10000/RTCM3_IMAX'
send position to base: single
type: ntripcli
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: true
version: null
correction:
format: RTCM3
started: true
version: null
interval: 24
overwrite: true
raw:
format: UBX
started: true
version: null
solution:
format: LLH
started: false
version: null
lora:
air rate: 2.6000000000000001
frequency: 868000
output power: 20
position output:
output1:
enabled: false
format: nmea
path: bluetooth
type: bluetooth
output2:
enabled: false
format: llh
path: :2013
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh
path: :2015
type: tcpsvr
rtk settings:
elevation mask angle: '15'
glonass ar mode: 'off'
gps ar mode: continuous
max horizontal acceleration: '1'
max vertical acceleration: '1'
positioning mode: kinematic
positioning systems:
compass: false
galileo: false
glonass: true
gps: true
qzs: true
qzss: true
sbas: true
snr mask: '35'
update rate: '1'
working DHCP discover from iphone
Bootstrap Protocol (Discover)
Message type: Boot Request (1)
Hardware type: Ethernet (0x01)
Hardware address length: 6
Hops: 0
Transaction ID: 0x3db227a6
Seconds elapsed: 33
Bootp flags: 0x0000 (Unicast)
0… … … … = Broadcast flag: Unicast
.000 0000 0000 0000 = Reserved flags: 0x0000
Client IP address: 0.0.0.0
Your (client) IP address: 0.0.0.0
Next server IP address: 0.0.0.0
Relay agent IP address: 0.0.0.0
Client MAC address: Apple_f2:3b:2a (3c:2e:f9:f2:3b:2a)
Client hardware address padding: 00000000000000000000
Server host name not given
Boot file name not given
Magic cookie: DHCP
Option: (53) DHCP Message Type (Discover)
Length: 1
DHCP: Discover (1)
Option: (55) Parameter Request List
Length: 7
Parameter Request List Item: (1) Subnet Mask
Parameter Request List Item: (121) Classless Static Route
Parameter Request List Item: (3) Router
Parameter Request List Item: (6) Domain Name Server
Parameter Request List Item: (15) Domain Name
Parameter Request List Item: (119) Domain Search
Parameter Request List Item: (252) Private/Proxy autodiscovery
Option: (57) Maximum DHCP Message Size
Length: 2
Maximum DHCP Message Size: 1500
Option: (61) Client identifier
Length: 7
Option: (51) IP Address Lease Time
Length: 4
IP Address Lease Time: (7776000s) 90 days
Option: (12) Host Name
Length: 3
Host Name: ssw
Option: (255) End
Option End: 255
Padding: 0000000000000000000000000000000000000000000000
NOT working from reach
Hops: 0
Transaction ID: 0x9c43f566
Seconds elapsed: 475
Client MAC address: MurataMa_7b:be:4a (fc:db:b3:7b:be:4a)
Magic cookie: DHCP
Length: 1
DHCP: Discover (1)
Length: 7
Length: 2
Maximum DHCP Message Size: 576
Length: 7
Parameter Request List Item: (12) Host Name
Parameter Request List Item: (28) Broadcast Address
Parameter Request List Item: (42) Network Time Protocol Servers
Option: (60) Vendor class identifier
Length: 12
Vendor class identifier: udhcp 1.22.1
Option: (255) End
Option End: 255
