In order to process data in OPUS I used Emlid Studio to reduce the file size. So I used the Convert mode, checked only GPS and set the epochs to 30 s. All good, I get the satellite view, but no SkyPlot (see the screenshots below). Why? Is it a bug?
There’s no skyplot because this observation file has no associated navigation file in the folder. I assumed you used the observation file to decimate the data?
If you convert a UBX file, for example, the Convert to RINEX option will also generate the navigation file.
If you want to check the skyplot for this decimated file, copy the navigation file from the original RINEX folder and paste it into the folder where you saved the decimated file. Then, rename the navigation file so its name matches your observation file. That’s how Studio associates the files and can draw the skyplot.
Thank you Ruth! I had the observation and navigation file in the same folder, but with a different name.
