Hey all,
Did my first night of observations last night.
Reach in rover mode recieving corrections from cors nerwork. 8 satellites observed from each station (grey bars showing). Single solution immediately the float solution within a couple of seconds but then no fix after half hour. My mode is kinematic. My base station is 8kms away but using vrs technique so i believe its irrelevant anyways and have sent my approximate position to base “single”.
I tried gps only and same result (no fix). I tried connecting to another cor base stn (15km) away and same result. I tried changing from 10hz to 5hz no luck. The float solution did seem very conistent however. I had the advanced settings as default.
I have rebooted the reciever and will try again soon.
Any advice out there?
