I only can collect Points when I have a FIX solution. But I also want to collect Points when I just have a SINGLE or FLOAT Solution. Is there an option in the app for that?
Have a nica day at all.
In Flow when the collection pane is up there is a gear at the top-left of the pane.
Hi Lauri,
To support Michael’s comment. This is the gear you need:
This will open the Survey settings tab, where you can disable the FIX only option. You’ll then be able to collect points in Single and Float.
Thank you for that very usefull reply
