We use a Reach RS3 as a BASE and a couple of M2s as rovers, with LoRa as the radio connection. There is no GSM coverage in the area. Is it possible to use LoRa for the M2 and in addition a WIFI connection for the local NTRIP for the DJI drone at the same time?
Hi @mik.krzywanski,
Welcome to our community!
Currently, you can set only one base output at the same time, so it’s not possible to use LoRa and local NTRIP simultaneously.
But thank you for the feature request! I’ve noted it and will add it as +1.
Hi @mik.krzywanski,
Great news! In 33 beta, we added the feature to use two different correction channels at the same time. So you can update your Reach device to the newest 33 beta 2 firmware and use it. If you are planning to test it, feedback is always appreciated! Please note that it is still a Beta version, so we do not recommend using it on work projects, just for testing purposes. However, these updates will be part of the stable version as well.
Beta updates need to be enabled first in the Emlid Flow Settings tab. If you need any help with that, you can write to us at support@emlid.com or start a new thread here.
