Hello friends,I want to use simple goto code from dronekit github to run on my navio.I can send simple goto my missionplaner but I can not send to my navio.how can I send thanks a lot
Hello,
Firstly I run these raws on cmd
dronekit-sitl copter
mavproxy.py --master tcp:127.0.0.1:5760 --out udp:127.0.0.1:14550 --out udp:192.168.1.46:14550
and then I connect Mission planer then I run my script.I use this connecting code in my script
vehicle = connect(‘udp:127.0.0.1:14550’)
But I can not see any movement on my navio but mission planer run
Should I enter the navio 2 ip address in the connection code above?(udp:192.168.1.46:14550)
Thank you for attention
Hi @earas48,
Sorry for the delay!
Could you please clarify which command do you use to run ArduPilot on Navio2? I’m not sure I understand that correctly.
It should be possible to run dronekit using either localhost (127.0.0.1) or RPi IP address.
Thanks a lot.I solved this problem utilizing 127.0.0.1:14550
