Hello, my SIM cards do not work on the RS4. I have confirmed the APN settings and SIM cards work in my RS3’s.
Hello, the SIM card issue still persists. I have used two different sim cards that work in the RS3’s, but will not work in the RS4.
Hello Joshua,
Thank you for reporting! I’ve brought your post here to keep everything in one place.
Since the 34.6 firmware hasn’t worked for you, I’d like to check a report from your unit with our devs. Can you please generate an FSR on the RS4 after attempting to connect to the internet via SIM, and send it to [email protected]?
It would also be very helpful to have an FSR from the RS3 with the same SIM inserted. Since the APN settings work there, this will help us compare and pinpoint the issue.
I think we have the same failure mode.
Hi Joshua,
I have received your files via email. I will be reviewing them with the team soon. I’d like to add that the RS3 and RS4 have different modems, so they can behave differently with the same SIM card. It is, however, helpful to the investigation to have them both, so thank you very much for sharing them!
Hi, I also had porblems with the sim card. My solution was to put in the card, connet via WIFI enter the APN setting. Switch off and on , connect again and enable mobile data.
hth
Hi @gnss ,
Do I understand correctly that you had the same issue, and you managed to resolve it by connecting to the receiver over Wi-Fi, entering the APNs, rebooting the receiver, and then reconnecting to it with the SIM card inserted? Let me know if so, and we can then see whether it helps other users with these issues.
We are still having the same issue with the SIM card connection on the RS4Pro (34.6 firmware). The 34.6 firmware does at least activate the SIM and provide a cellular connection and fix solution for about 1 minute, then it drops out again. If you reboot the receiver, it will give me about 1 more minute. I’ve been using my phone data as a work-around but it gets old handing off the receiver and my cell phone to my helper…
We are using the Eiot Club SIM. Are there known work-arounds or tricks that will make the SIM card data connection work?
The dropout pattern you mentioned is a useful detail. Can you let me know, when the connection drops, does it fall back to 3G before disconnecting, or does it just cut out from 4G/LTE directly?
Also, can I ask, are you using the EIOTCLUB Double Play or the Triple Play SIM? We’ve received reports that the Triple Play doesn’t work with the RS4 Pro, while the Double Play has worked for other users. If you’re on the Triple Play, maybe it’s worth checking the Double Play.
Beyond that, we’re aware of this, and the devs are working to address a few SIM-related issues. Will keep you posted once I get any news
In the meantime, if switching SIMs isn’t practical, sharing your phone’s hotspot or using NTRIP via mobile device is a more reasonable workaround, though I understand that’s not a long-term fix.
Keith-
I appreciate your reply. We tested the RS4 Pro this morning. Once the receiver fully boots and beeps, indicating a fix solution, the cellular connection maintains fix for exactly 1 minute. The Flow app (upper left-hand corner of screen) indicates LTE and does not change to anything else. During the 1-minute fix solution, the age of corrections bounces back and forth, but slowly increases until finally reaching 10 seconds. At that point the receiver then goes into single-position solution and does not recover. This was the same scenario for four full re-boots today.
We experience the same issue on all other base stations throughout the correction service network. The RS4P worked flawlessly before the notorious firmware update.
We use the EIOT Club SIM. None of the literature indicates Double-Play or Triple-Play. It’s for data only, unlocked devices. 24GB/1-year service. Has worked in the receiver before the firmware update and in all of our RS3’s. We have switched the card twice, thinking we had bad SIM cards. I’m willing to try another SIM that you know works in the RS4P.
Thanks for your help. -Jeff
Ah, I see. From what you’ve described, this sounds like an issue we have flagged on our side, especially since you mentioned you can reproduce the same behavior with other receivers. We are working on the solution and will keep this thread updated for you once I get any news.
In the meantime, would working with Wi-Fi or trying a different SIM card help as a workaround? Let me know your progress on this.
Hi guys,
I just wanted to let you guys know that we have released firmware 34.9 for the RS4 and RS4 Pro.
This release includes fixes and improvements that should enhance how our receivers behave with SIM cards. Once you have updated the receiver’s firmware through the app, I believe that the issues reported here should be resolved.
When you can, please feel free to share your thoughts and feedback on this : )
I just tried the EIOTclub Triple Play from my Netgear Nighthawk MiFi router on my RS4 Pro, and it still doesn’t work. The dual play still works correctly.
