Good morning,
I am using the Navio2 for a seafloor mapping project that runs Ardurover. I can connect over udp in mission planner, and just received two new SiK 915 mHz telemetry radios- one is connected to the USB port on the RPi and the other to my laptop. When I try and connect to the vessel over these radios, it times out and says no heartbeat packets received. I have included screenshots of my current configuration on the RPi and on Mission Planner. I have UDP as telem1, telem2 as telemetry over USB, and my sonar is connected to the UART port over telem3. I have browsed through the forums, and I do not believe that it is a baud rate issue. My goal is to connect to mission planner via the telemetry radios and connect the software that the sonar runs to the UDP connection at the same time. Has anyone run into this issue before? Any tips or tricks would be greatly appreciated.
Thank you for your interest,
-Jake
