We’ve got a Navio2 board connected to an RPi3B+ and everything works with regard to ArduPilot, but we want to run some additional software on the RPi. This software needs GPS data (for position) and an accurate time source (NTPD). We added a jumper from pin 3 of the U-blox chip to pin 12 of the RPi header (GPIO 18) to get the PPS signal, but the real hold up seems to be that ArduPilot is going directly to SPI to get the GPS feed from the U-blox chip.
Is there any supported way to configure ArduPilot to read the GPS data from a PTY (such as with the ublox-spi-to-pty utility)?
That’s right. You can get the data by accessing the Navio2 chip via SPI. You can check the Python/C++ examples that show a way to decode UBX protocol messages. These scripts will provide you with the messages with current location data.
Please note that it doesn’t seem feasible to get the PPS output from the Navio2 chip.
Perhaps I wasn’t clear – I need to have GPSD AND the ArduPilot software running simultaneously, each getting GPS data, and I would like suggestions on the best way to do that.
IMO having GPSD parse the GPS feed and then having ArduPilot pulling GPS data from GPSD would be the best solution, but apparently ArduPilot isn’t set up for that, so I’m looking for a plan B.
It might be quite tricky to do so. ArduPilot and GPSD might be using the same resources, which might lead to conflicts and distorted values. That’s why we don’t recommend running any of the Navio2 examples while ArduPilot is enabled. It’s better to use GPSD separately.
