So my saga of bluetooth and custom ntrip integration has uncovered a fairly severe issue with settings persistence. If you access the rs4 from different mobile devices via flow AND via rs4 wifi hosted web panel…any ntrip related settings get completely mixed up lost orphaned depending on which device or connection you set them from. You guys need to sync settings data better across all methods of interfacing with the rs4. basically if you touch anything in the web panel you can expect deleting the app and refreshing the rs4 to unravel the mess.
