I set up a base and rover over the NTRIP caster. My questions
Are there specific mount points for each area, or you can select any mount point (same for both base & rover)
What password should be used and what user name?
Are there any other setting needed
Hi Raed,
Welcome to our forum!
You can select any mount point that is available for your account in Emlid NTRIP Caster. Still, the mount point should be the same for the base and the rover to transfer the corrections. You can follow the instructions from the How to connect your base and rover to a mount point guide to set it up.
