Hi Fred,
The functionality of embedding the telemetry radio as a carrier for RTK corrections is available in the Mission planner only. If you’re using another configuration software, you won’t be able to use this feature.
Yes, I mean the Ground Control Station, probably laptop with a running Mission Planner.
Yes, that’s what I meant. Could you please share the screenshot of the Status tab of the Reach M2? It’ll help us check if Reach can send the corrected solution to autopilot.
