In the meantime, the only way to get the raw data from Reach is to download them manually in the Logging tab. It’s not possible to output it in the same way as position, I’m afraid.
May I ask you to tell me a bit more about why you need this? Maybe I can recommend a workaround.
We are going to equip a fleet of 20 vehicles which will cover around 80,000 km each spring to analyze road conditions with an on-board system that collects information from different sensors and the GNSS position.
To increase the accuracy of positioning by GNSS, we will use the PPK using the GNSS data from the vehicle and from the different fixed bases installed by the government on the territory.
When the driver has completed his journey, he connects the vehicle’s on-board systems to the central system and the data transfer is automatically started. When the transfer is complete, the classification and analysis of the data are automatically carried out.
As the system is fully automatic, it is also necessary that we can transfer GNSS data without human intervention. As we are satisfied with Emild’s products, we would like to use them in this system.
We don’t have a ready solution for such a task, however, if you’re experienced in working with Linux systems, you can ssh into reach and use rsync to get the data remotely.
