Hello! I wondering how i could send controls directly from the rpi. I will have a program that will filter the user commands and generate a automatic control based on sensors without a ground station.
Thanks a lot
Thanks a lot
Thanks Igor… if I understood well, I need to input my code in arducopter and recompile it. Is it?
It looks amazing Igor. But when I told you about using arducopter, I mean I intend to use the navio2 arducopter version in rpi. As I could check out the examples, Seems not to be too difficult inputting my code in the “arducopter navio2 version”, maybe creating a new flight mode. The dronekit solution looks good when accessing another autopilot as Pixhawk. Or is it better using the latter solution even when running in rpi + navio2? Did I understand correctly? Please, correct me if I’m wrong.
Thanks so much for your help.
You can actually run dronekit on the same Raspberry as arducopter.
Thanks Igor! I will give it a try
