As there have been a few people commenting about using 3rd party hardware (Topcon) to access an Emlid base using nTrip, it really is becoming difficult to manage all the mount points that everyone has been adding. Since it’s not possible to alter Topcon’s software, I’m out of options on that end.
One solution I could see, is the ability to host the nTrip server ourselves. Which would mean not having to use Emlid’s servers at all (or their data).
I know it’s already possible to use other software to self host. But the east of use of Emlid’s caster is way higher than anything else I’ve tried.
Alternatively, if Emlid could give a custom URL that would only send out mount points linked to our account, that might work as well.
I get what you’re asking for — basically the same dead‑simple workflow as Emlid Caster, just with your own URL and only your own mountpoints showing up. The thing is, Caster is built as a shared, lightweight service. Once you start talking about private namespaces, custom URLs, DNS/SSL, and per‑user routing, you’re in a totally different tier of complexity.
That’s not really what the free caster is designed for. If you need a private setup — especially because some receivers dump every mountpoint into one giant list — the realistic answer is to self‑host with SNIP, RTKBase, BKG, etc. Nothing’s wrong with Emlid Caster; it’s just not built for that specific use case.
Since this involves third-party hardware, it’s more challenging to have complete control over it. I’ve submitted a feature request to support loading a mount point that is only linked by its own credentials, which may improve the workflow. While this is not currently on our roadmap, I will keep you updated if there are any developments.
I have also shared your feedback regarding the custom URL with the team. Thank you for your input!
We use YouCors after EMLID has disabled EMLID Caster Pro - this is for all of our machine control fleet and works flawlessly, and is private so only your mount points show. There is a charge depending on how many mount points you require etc
