Hi Everyone,
I have a Seg fault when I try to start a ROS node (that work fine with the raspberry pi 3 image).
Do you have a idea about it ?
Thanks
Hi Silvain,
Unfortunately, at the moment it’s quite difficult to determine what might cause the issue. Would you mind specifying the Image and ArduPilot version you use?
Could you please describe your actions step-by-step?
It’d be great if you could post the screenshots of the issue occuring.
Hi Polina,
The probleme come from the ros installation. I reinstall ros and it’s work fine.
Silvain,
Great to know everything works fine now! Thanks for the update
