Do you have another SD card at your disposal to test Navio+ with? I know that some of our users resolved the issue by changing the SD card. If you have one, it can be useful to test it out.
As I see, you’re using a brand-new Raspberry Pi board. Have you tried working with this Navio+ earlier using another Raspberry Pi? I just want to understand at what stage the issue appeared.
Thank you for the quick response. I do have a couple of other SD cards and I have tested them with the same issue.
This is the first time I work with the board but I have had it for a while. Is it helpful for you if I try to find another raspberry pi board to test Navio+ on?
Since the behavior repeats, we can conclude that the issue isn’t on the Raspberry Pi side. Probably, something is wrong with the physical connection between Navio+ and the boards. Can you check that the pins on the extender aren’t tilted in some way? Does Navio+ sit tight on that pin extender?
PS: I did reflash to the latest image, I was afraid I was doing something wrong with the wpa_supplicant.conf file. But it worked fine with the latest image.
Oh, I forgot to mention that Raspberry Pi 4 8GB is supported with the latest image only.
However, it’s still better to check Navio+ with Raspberry Pi 2 to understand whether it works with the previous image.
Maybe, the psk parameter was commented. Usually, I forget to uncomment this parameter and wonder why the device can’t connect to the network . Can you double-check this?
The previous image should work with RPi 2 boards, but it seems that something unknown to me produces such behavior. Also, I can’t be sure that your Navio+ doesn’t affect this too.
We went through all possible steps to troubleshoot the issue with Navio+ with you so far. I believe the board has hardware-wise issues causing it not to be recognized by the software.
Please, check your PMs as I’ve messaged you there with a further suggestion about this case.
