Before acquire the unit we need to know if Emlid RX sends position data over USB C to PC or not. Thank you.
Hi @ballcir,
Welcome to our community!
Reach RX outputs its position only via Bluetooth. Other Reach receivers also support the Serial and TCP options. So, if streaming the position over USB is required for your application, I’d suggest checking Reach RS2+.
Would you mind describing your application and the desired workflow? It will help me provide more suggestions for you.
