Hi Erik, here probably one mistake at the beginning is the cause. I checked through the station with CORS. the interval on the base is 1 second and the rover is 0.2 seconds. then the consequences of these errors.
Regards ROVE0750.pdf (98.7 KB) report_2018-03-16_Static.pdf (886.8 KB) 20180316.zip (3.4 MB)
So both of them should be exactly the same interval? either 1 second on both or 0.2 seconds on both? If that is the case, why either BASE or ROVER can be correctly processed when using the MTY2 which sampling is 30 (also different). I just want to understand
No. I only compared your rinex files with my, which I checked by postprocessing. Intervals can be different.
Before rtkpost, it is necessary to check what arose from rtkconv.
Regards
