Good morning,
today, I performed a survey with my REACH RS+.
I just completed post-processing of my data, but things are not working properly. I used my REACH along a straight path, but post-processing gives me as a result a very scattered cloud, located not in correspondence of my path, but in correspondence of the base.
Why is that? How can I solve this issue?
I selected as input files the OBS from the Rover and the other two Rinex files of the base that I downloaded online.
Also, during my survey, I’ve always been in Single mode, never in Fix or Float.
Thank you very much.
This is the link: https://we.tl/t-ywA6UP6gjX. This folder contains the Rinex files from the Rover and Rinex from the Base downloaded from the web.
These are other informations from the Base:
There seems to be no temporal overlap. You need to retrieve the logs from the base station for the correct period during which you made your observations with the rover. There should be twenty-four 1h period files to choose from; you might need more than one to cover the entire observation.
Check the header of your rover RINEX file for the timespan. Time of first and last observations are listed.
