I’m trying to post process some data that I have adquired with EMLID’s RTKPost.
My base station was left for a long time and the .OBS file ended up with 120mb. The result was that I cannot do Combined-Pass post-processing. It gives me a memory leak error.
This is not exactly a leak, but more like inefficient memory usage. Unfortunately, with really big logs RTKPOST can behave like this. Your best shot is either cut the log by specifying the time, or use a PC with more RAM.
The strange thing is that rtkpost from rtklibexplorer works fine with even bigger logs (600mb+). Your fork works fine with the same log using just the forward pass. It seems more like a bug with the combined solution.
PS: is there some tool to cut the log or should I do it manually on the .OBS?
