I am trying to create a GPX from Reach M+ events POS and get this error. I can use the full track POS. It had quite a few floating events. More than normal.
I just verified that the events POS files are just 1kb and only contain the header data…
Just brought the full track into Geosetter and the path is rotated 180 degrees.
It seems like something messed up in log names. If you process rover.ubx as a base.ubx and vice versa you’ll get _events.pos file.
base_events.pos (20.7 KB)
Thank you very much. I will try that.
