Question: should we be changing from L1 to other options (such as L1+L2+L5) to reflect the multi-band capabilities of the RS2?
Additional reference: Page 35 on the 2.4.2 RTKLib manual, it describes Frequencies as “set used carrier frequencies” where L1 is single frequency compared to the other selections of dual frequency or triple frequency.
L5 stands for the Galileo E5b frequency band. So, if you enable the Galileo constellation in ReachView and RTKPost and choose L1+L2+L5, the data from the band will be used in the calculations.
Sorry for misleading you with the RTKPost notation.
Our multi-band receivers can provide the following frequencies:
GPS/QZSS L1C/A and L2C
GLONASS L1OF and L2OF
GALILEO E1-B/C and E5b
BEIDOU B1I and B2I
In the RTKPost notation, all these frequencies are included in the L1+L2 option. So, with the L1+L2+L5 option enabled, the same data will be used in calculations.
Please note that to convert all data in RTKConv you need to mark L1, L2, and L7 frequencies.
