Hello,
I am trying to find a definitive answer of whether RTKLIB is handling the Antenna Reference Point (ARP) values entered in the Delta-E/N/U (m) fields correctly?
I am recording static data with a base station and rover using the same models of tripod and antenna so heights are both the same at 2.083 m. When I post-process the logs in RTKLIB (ver.2.4.3 b28) the ARP vaule for the base station adds elevation to the rover solution and the rover ARP subtracts from the solution (see below).
Elevation [m]; ARP; diff [m]
2290.626; none; n/a
2290.625; both base and rover; 0.000
2292.710; base only; 2.084
2288.541; rover only; -2.084
It makes sense for the rover ARP value to be subtracted from the solution, though I am not so sure why the base ARP value adds to the rover solution for DGPS. I could see it making sense for RTK but this is static data and no LoRa. What am I missing?
Thanks in advance for any valuable insight on this.
Cheers,
Christian
