RTKLIB issue
Strange behaviour here with the RTKLIB I get from Emlid doc (2.4.3 b16).
When Reach is on, I have correct RTKplot real time positions through TCP.
If I get Rinex log and try to plot the solution (single mode) : “No solution data”
With the same Rinex file, with RTKLIB 2.4.2, I get the correct figure :
One step before, sat vis plot from same Rinex file give this under each RTKLIB release:
With obvious wrong interpretation for L2 records on 2.4.3, where 2.4.2 see only L1.
I am looking for time mark location, so 2.4.2 is not helping me a lot, despite it gets the correct plots and solutions.
So if I try an other way to extract marks, how can I find Time marks inside Rinex file ?
Are you trying to plot RINEX as a solution? RINEX contains observations, not coordinates.
Of course I plot solutions after single Rinex postprocessing on top of post, the raw observations are side by side on figure below.
Can you please send me your logs to support@emlid.com. I think that there is an issue with the posted RTKLIB, we are investigating.
Hi Igor,
Any chance for you to update your RTKLIB release ?
Pascal
Hi Pascal,
It has been fixed and updated .
