Hy Emlid team
I tried to post process a Kinematic acquisition using Rinex base station network and your custom version of rtklib
RTKconv works for ubx data of my reach but when I tried to post process using rtkpost_emlid_b27.exe I’m not able to use the data downloaded from Base Station (attached the example) antoher issue is that the base station observation are per hour so if my acquisition is between 15.00 and 16.00 I have to use 2 rinex base station file to perform the post processing but I’m not able to select multiple files.
I hope my explanation is clear enough
In rtklib standard I can choose for base sation both multiple files and original zipped format
Thx
Francescopado104P.17d.Z.zip (795.3 KB)
