Could you specify how powerful is the USB outlet of your power banks? There might be some issues if you are using 5V 1A output since only the radio takes half of that power as far as I see from the datasheet.
Also, had you tried substituting the radios? I don’t see any LEDs blinking, maybe that is related to the power supply case, which I had described above, however, it could be the hardware issues of the radios.
As far as I see from the photos, you use 6 wires to connect the radio. Please try only with 5V, GND, RX and TX. Radio has CTS and RTS on the other two legs and it might be confused by their state.
Apart from that, the only issue possible is cabling itself, that happens sometimes with DF13 connectors.
Would it make sense, if I change from PowerBanks to USB-AC/DC-Adapters for testing puposes? I have two adapters with an output of 5V and 2A. Could that help to isolate the issue?
Substitution of radios:
Yes, I tried a second pair of radios. Same behaviour. But will try again with the power-adapters mentioned above.
Please, try lowering the baud rate to 9600. By default, it is recommended to use 57600.
I think it is worth establishing a connection between the Reach Modules first and then troubleshooting the ardupilot. However, if the change of the baud rate will help, don’t forget to change it into the ardupilot settings.
We will try to reproduce the issue and come back to you with the feedback as soon as possible. Could you please specify the firmware version you are running?
Currently, the version v2.20.8 is installed. As indicated at the top-right corner of the ReachView application.
I don’t know, if it is meaningfull, but I checked the serial-outputs of the module in three different status with an oscilloscope (TX and GND). From my understanding it looks ok, does it?
Thank you for the oscilloscope pictures. Based on that I could say that the signal shape is the one we expect.
We had replicated the setup and we had not encountered any issues. Could you, please, make sure that the radio connection is the following:
TX -> RX
RX -> TX
GND -> GND
5V -> 5V
So far it looks like there might be an issue with cables or radio itself. Could you, please replace the cable between the Reach module and the radios? I remember asking you to check the cabling, however, I think that is likely the issue.
Also, could you test these radios on another equipment in order to eliminate the Reach from the setup? We also recommend using the latest versions of our firmware (v2.22.4), available in the ReachView app.
I started from scratch and was soldering all cables according your replay. I totally missed the crossed cables of TX and RX.
That was caused because I was using the original cables.
I am sorry for the current issue. It works perfectly and very stable now.
