@timkaiser
I’m using the Ublox NEO M8N over USB, there I get about 10 Hz RAW Data. But I have to disable SBAS and NMEA output, and output to all not used peripherals (in my case UART,SPI and I2C) and I need a higher baud rate (about 230400). These configurations could be done with the u-center.
I don’t know If it’s possible to get 5 or even 10 Hz over SPI but you could try it by adding one command to the ubx_spi_m8n_glo_raw_1hz.cmd:
@mikhailavkhimenia
GPS and GLONASS enabled, SBAS and NMEA disabled
All unused peripherals (uart,spi,i2c in my case) disabled
I can not confirm exactly 10 Hz since I am using rtknavi at the moment, there is only a flashing green rectangle, but with the CFG-RATE config. it’s flashing faster
There are other people in this (german) Forum http://www.gpsforum.geospector.de/phpbb/viewtopic.php?f=3&t=3503&start=15 who also get more then 1Hz RAW data from NEO-M8N
@No_Peppermint
I used two ublox m8n with rtknavi. and get 5hz data, gps and glonass enabled. and i set output solution with serial type and nmea format. After it got float quality, I get nmea sentences by connecting serial port, but the position and velocity are not correct. however, rtknavi can plot the position correcttly. This only happened in the m8n navigation rate larger than 1hz.
