I was wondering what was the difference between the RTCM3 message rates between those two menu sections. Found that the message rates in Base Mode cannot provide what is expected in terms of rate (example 2Hz at twice per second) and constellation selection if the RTK section RTCM messages are not selected and with an appropriate rate that is at least as fast.
I had to conclude the RTK settings affect also Base Mode. Is it normal?
