If getting two units (Base and Rover), would it be possible to output the RTCM correction via a serial connection from the Rover? i.e. the rover will act as a modem rather than fully functional rover …
The RTCM corrections should output via serial at 1Hz minimum.
Also, a question for Emlid guys, are there any plans in the pipeline for making Reach-RS with radios in the 433Mhz band … ?
Thanks for replying Igor.
The use case I have in mind is this - two reach-rs units to be used for combined Aerial and Hydrographic surveys in remote locations.
Two reach-rs units to be used on a typical Base-Rover for Aerial survey GCP.
Then, one unit as base and one unit onboard a survey vessel to output RTCM (via serial) into survey equipment top unit (already have dual-antenna GNSS integrated).
In the use case above, would it be possible to output RTCM (sent from base) onboard the survey vessel using the secondary reach-rs unit?
