I’ve been using two fixed EUREF RTK base stations to use to experiment with RTKLIB and I’ve come across a problem.
The two stations I use are SCOA00FRA set as BASE and PASA00ESP set as ROVER. I download and saved the RTCM live steams from each using STRSVR one instance for each station, then converted to RINEX with RTKCONV to get the NAV and OBS files. Then RTKPOST the BASE and ROVER OBS’s and NAV files. However, this only works (Q=1) with the ROVER using the BASE file and the BASE using the ROVER file. The ‘normal’ way ROVER as ROVER etc doesn’t work.
I’m thinking this is a problem with the RTCM files generated by the stations ?.
Dave.
I’ve attached the RTCM BASE & ROVER files RTCM-files.zip (3.2 MB)
Ah ok, how did you work that out ? I was just ‘messing’ with fixed station data to see if it was even possible. I guess some stations are configured differently from each other.
Is it possible, I also started that way, before I got my own units.
However, some stations are just better than others, and it is difficult to say why.
Sometimes this can be fixed by changing settings, sometimes not. Using precise orbits / clocks can also be advantageous.
