Thanks for the quick response Igor.
From the two very different views I’m hearing it appears the misunderstandings from last year have continued. Back in April I posted this RS3 tilt compensation work with external software - #14 by Wombo with a suggestion to try and establish regular technical engagement with MicroSurvey. It would seem this is now needed more than ever.
I’m getting the feeling it could be as simple as confusion in that they may believe they’ve been instructed to use the later basic method. For example, hence needing command capability to…propagate the antenna height which was a point mentioned.
Over to you, thanks.
