While the documentation provides detailed instructions on setting up Wi-Fi connections and using the device with the Emlid Flow app for operations over Wi-Fi, it does not explicitly mention simultaneous operation of both Wi-Fi and Bluetooth Please verify both can be operated without interruption to each other.
Hi @engineering_305,
Sorry for the silence here.
Yes, you can connect to Reach RS3 via Wi-Fi and stream position from it via Bluetooth at the same time. Is this the workflow you want to work with?
I’m thinking he has mentioned connected to the unit via WiFi and Bluetooth at the same time. For connecting 2 data collectors at once . It only connects to one at a time . I have tried connecting my windows tablet FG and android at the same time . no go
Hi Dave,
Why would you need a connection to the same unit on two different devices at the same time? Can you please share more details about it?
