Hello
I’m trying to use RS3 with Land Star 8 as I know tilt compensation will not work (will it?!)
My steps like this
- In config tap Instruments profile clicked
- New the instruments type GNSS Rover
- Then these option were selected
Is this a good numbers or should I change them?
Does Tils compensation work with Land Star8?
If any one have test the land star 8 with RS2 or RS3 please share you thought :)\
Waiting for your answer and thank you all
Hi @AbdUlaziz,
There can be two possible ways to use the tilt-compensated coordinates in this case. Streaming Reach’s position to Land Star 8 is required in both cases, so it should be able to receive NMEA messages.
If your software supports receiving our NMEA ETC message, you can obtain information about the tilt compensation in it.
In firmware version 32 beta, it’s possible to stream the tilt-compensated values in the NMEA GGA and GST messages. To access it, let’s update the firmware to this beta version.
I can help you configure position streaming at any time if you’d like to.
Yes, you can work with these values.
