RS3 base with Trimble R10 rover
Can I setup a RS3 base with UHF Harxon radio and receive the corrections on a Trimble rover (R10)? Also will the NTRIP work in this setup?
What kinda of signal does the harxon accept?
You can easily use it over NTRIP, yes.
Not exactly what u r asking… but maybe using a separately purchased UHF antenna for the RS3 (rover), it can ONLY RECEIVE UHF (not send) from the R10 (base)?
Seems to me a new future model Emlid should come with a built in higher powered UHF radio that can BOTH send and receive.
Related posts re NTRIP from a couple of other R10 users:
Hi Simon,
Welcome to the community!
You can activate the RTCM3 legacy message to use RS3 as a base with Trimble. For the connection, you can use Emlid Caster.
Could you share more about why you need to use the UHF Harxon radio?
