RS3 Base/Rover combo in a remote area without Internet
There’s nothing wrong with AUSPOS. I use it multiple times a week and have for many years along with other GPS/GNSS services and various post processing software like RTKLIB.
For the original question a service like AUSPOS or CSRS-PPP is best if you don’t have long baseline GNSS processing experience. How long should you observe? AUSPOS suggests a minimum of 6 hours. This is for a receiver which has dual frequency measurements on all GPS sats. A L2C only receiver won’t - so up the observation time a bit. The sats without L2C can “bunch up” making certain time periods of an hour or two not so great for dual frequency GPS.
Use both services and compare the results. A half a day of data is a reasonable time period for cm-level results. Obviously more time will increase your confidence level.
Yes, with sufficiently long occupation times, cm level accuracy is possible, given it is a PPP solution (not PPK)
Alternatively, you can install a CORS in your region.
I’ll bet someone will sponsor you.
The requirements aren’t as onerous as they may seem. Just buy used equipment.
Worth a thought.
https://files.igs.org/pub/resource/guidelines/Guidelines_for_Continuously_Operating_Reference_Stations_in_the_IGS_v1.0.pdf
