Me again, I was wondering what is the level voltage of the RX TX and PPS signal of the RS232 connector of the RS2.
I would love to read that is all 5V.
Also, is the PPS signal ahving a resistor before the output because I intent to put this signal to a GPIO that got a Zener Diode in front of it.
RX pin of RS-232 interface accepts levels from ±3 V up to ±25 V. TX level is at least ±5 V. PPS signal is a 3.3 V CMOS signal and has no series resistor.
Thanks, so what is the maximum length allowed for the provided cable since PPS is a 3v3.
We would need at least 5 m for our applicaiton but we are afraid to loose signal.
Is your cable shielded also ? what are your recommendations ?
The maximum cable length we provide for the 9-pin bottom connector of RS2 is 2 meters. You can check one without the second connector at our store. Longer cables may cause a significant worsening of the signal. So, I wouldn’t recommend using longer cables with our receivers.
