I own several rs+ units and I am currently using the mirosusb 2.0 port to send USB-PC position output using NMEA messages. Our current application is used outdoors and because of that I assume the LEMO connector will be more robust. I currently have the LEMO connector with out the second connector, what other hardware and what connections have to be made to be able to connect to a PC and relay the same NMEA messages and also leverage the power functionality of the lemo connector on the bottom. I am fairly new to communication protocols so a simple diagram used to wire the connector up will be much appreciated.
If you’d like to use the USB port of your computer, then you need a converter.
You don’t need those pins for the position output. Event pin can be used for recording time-marks in the raw data log and the PPS pin can be used for the synchronization with external hardware.
